fix "curly braces" error in rsobj file
Thread begun 12/14/2021 3:43 pm by randyrie405335 | Last modified 12/15/2021 12:52 pm by Ray Borduin | 1215 views | 3 replies |
randyrie405335
I copied over to my PC via FTP a couple of my websites and am getting this error:
"Fatal error: Array and string offset access syntax with curly braces is no longer supported in C:\xampp\htdocs\RjRwebz\webassist\mysqli\rsobj.php on line 145"
What is causing this and how do I fix this?
You can reinstall the latest version of DataBridge and it should be corrected. After you reinstall, just re-apply any recordset and it will update the rsobj.php file.
randyrie405335
queryobj.php error
re: Windows 11, DW CC 2020 ...
I removed the DataBridge extension and then re-instsalled it, opened the affected.php page in Dreamweaver CC 2020 and rewrote the recordset but I'm still getting a 'curly bracket' error:
Fatal error: Array and string offset access syntax with curly braces is no longer supported in C:\xampp\htdocs\RjRwebz\webassist\mysqli\queryobj.php on line 414
I do not have this issue on the public server or my Mac's localhost, (neither of which run under Xampp)
Now it is in the queryobj.php file... you would have to reapply an insert or update server behavior to update that file as well.
