Field Name Change In MySQL Causes Dreamweaver 2021 to fail.
Thread begun 12/07/2021 4:05 pm by p03976803142 | Last modified 12/07/2021 5:24 pm by darren180801 | 1014 views | 1 replies |
p03976803142
Hi, I use Dreamweavefr 2021 and WebAssist with a large number of tables in a dynamic web site. All was working very well until today when I was forced to change a few field names in one of my mySQL tables. Using phpAdmin, the table fieldnames were changed. I went back to make corresponding field name changes in web page dynamic tables but Dreamweaver crashed. DW reported that "A script named UNKNOWN was taking too long to run". I'm pretty sure that the script that failed was a WebAssist script. Does WebAssist need to be refreshed in some manner? It seems that WebAssist is not aware of the field name changes. What should I do in WebAssist if I need to change field names again in the future?
Dreamweaver should automatically detect the column change. I'd have to debug this one. Can you send me your Dreamweaver site definition file and I can see if I can spot the problem. I don't think this is related to the column name change, but you might want to try clearing your winfilecache .dat file to see if that helps. If you want to contact me via skype (webassist.rborduin) then I could do screen sharing with you and try to debug the issue that way as well.
