Sending email to all records in recordset using Send mail
Thread begun 12/02/2021 2:34 am by info252084 | Last modified 12/03/2021 9:03 am by Ray Borduin | 1832 views | 4 replies |
info252084
Hi, Is it possible to send an email to all the records in a recordset using Send mail? Now only the first record is used.
File attached.
regards, Peter Drieghe
Open the "Create Email Message" server behavior. Then click the "To..." button. You will see the send email from recordset option on that page.
info252084
I managed to insert the server behaviour, the code has changed, but the email is only sent to the first record in the recordset
Change line 10 from:
$emailadressen = new WA_MySQLi_RS("emailadressen",$spice,1);
$emailadressen = new WA_MySQLi_RS("emailadressen",$spice,0);
That will make the recordset return all results instead of just one.
info252084
Yes, now it's works fine.
Thank you for your awesome support!
