Update page not updating nor going to the GoTo page
Thread begun 11/29/2021 9:42 am by birdscreen398247 | Last modified 11/29/2021 1:46 pm by Ray Borduin | 1216 views | 4 replies |
birdscreen398247
See attached file.
It is not updating the table nor going to the GoTo page.
Frank
You don't have a method for your form... try updating: <form> to: <form method="post">
Also the form trigger is set to react to a hidden form element that no longer exists. Update your server behavior and change the trigger to be the form button that is currently on the page.
birdscreen398247
I don't understand.
Where in the code does it say the submit button should react to an element that doesn't exist?
Under server behaviors, I don't see one for submit, so I can't change it.
The trigger for the Update Record server behavior is set to react to: $_POST["MM_update"]
There is no "MM_update" form element on the page. To fix the problem, open the MySQLi Update Record server behavior and select the button press trigger from the select list.
birdscreen398247
That worked.
I used the generic Update Behavior instead of the WebAssist one.
