STARTTLS with smtp?
Thread begun 11/29/2021 7:06 am by Mags | Last modified 11/30/2021 8:54 am by Ray Borduin | 1940 views | 6 replies |
Mags
STARTTLS with smtp?
Hi Ray, our client is moving their email to MS Exchange and I need to update the Universal Email settings we currently use to send email via their website. The details they gave me said to use STARTTLS, however the only options given in the smtp authentication settings are ssl and tls. I tried using tls (this is what the current script uses) but it didn't send. I also tried adding STARTTLS manually:
$Email->SMTPSecure = "STARTTLS";
That didn't work either. Is there a way I can use STARTTLS in the script?
It should work with:
$Email->SMTPSecure = "tls";
If it doesn't, turn on Debug and see what it says. Maybe you have to update the port.
Mags
Turned on Debug and chose level 3 - where does the debug info appear? All I got was my own failure message that displays when a message doesn't go. I'm using the port number they gave me, which is 587, and have authentication to tls.
It should display it on the page... Turn off the redirect and that might help allow it to display. Level 5 might give more information.
Mags
Got it to display this time - I've put the errors in the PM section but looks to me as if the problem is at the client's mailserver end, do you agree?
My guess is that your server has a firewall blocking port 587.
Try port 25, that might work. Otherwise talk to your hosting provider and see if there is a way to open port 587.
Mags
I checked the firewall (it's a dedicated server) and port 587 doesn't seem to be blocked, however I tried changing to port 25 and it seems to have worked - just waiting for the client to confirm they've received the test email OK. Thanks for your help!
