Query not retrieving the correct record
Thread begun 11/17/2021 9:23 am by birdscreen398247 | Last modified 11/18/2021 9:17 am by Ray Borduin | 739 views | 2 replies |
birdscreen398247
In the attached file, the query at lines 67-72 is not returning the correct link.
It appears it is not getting the right ID value in this line: $rsebird->bindParam("i", "".($rsRecordView->getColumnVal("ID")) ."", "0");
What am I doing wrong?
Frank
Is "ID" the correct column name? What happens if you write it to the page:
<?php echo($rsRecordView->getColumnVal("ID")); ?>
birdscreen398247
I found the problem.
In the following query, there are two ID fields. One in the PORC_records table and one in the PORC_classes table.
$rsRecordView = new WA_MySQLi_RS("rsRecordView",$siteguide2018,1);
$rsRecordView->setQuery("SELECT * FROM PORC_records
LEFT OUTER JOIN aou_list ON PORC_records.species_number = aou_list.SPNO
LEFT OUTER JOIN PORC_classes ON PORC_records.PORC_class = PORC_classes.PORC_class
WHERE PORC_records.record_number = ?
$rsRecordView->bindParam("s", "".(isset($_GET['record_number'])?$_GET['record_number']:"") ."", "-1"); //colname
$rsRecordView->execute();
So I changed the name of the PORC_classes.ID field to IDN and that fixed the problem.
