progress bar interferes with jQuery Validate
Thread begun 11/15/2021 12:30 pm by s.joiner74419001 | Last modified 11/16/2021 12:57 pm by Ray Borduin | 1624 views | 6 replies |
s.joiner74419001
I have a form inside a modal that uses the 'JQuery Validate' plugin for validation. the form also enters data into database tables.
this all works fine until I add a progress bar to the form. In doing so stops the JQuery validate from working and submits the form even if empty.
Whats wrong here?
Page attached.
Thanks in advance!
I can't spot the problem. Can I see it live so I can use a javascript debugger?
s.joiner74419001
Ray see PM
I see... The progress bar doesn't know the form has failed validation. If you give me FTP access I can debug and fix it.
s.joiner74419001
See PM
Many Thanks Ray
I updated webassist/progress_bar/jquery-blockui-formprocessing.js to add support for your validation code.
s.joiner74419001
That's fantastic.. Thanks Ray!!
