SQL query problem
Thread begun 11/07/2021 10:45 am by birdscreen398247 | Last modified 11/08/2021 10:57 am by Ray Borduin | 1523 views | 6 replies |
birdscreen398247
SQL query problem
The following query is not working. When I try to test it in Dreamweaver, it tells me I have an error in the line starting with "AND (PORC_Votes.batch_date = ? OR PORC_Votes.batch_date2 = ?)"
Are the JOINS stated properly? Is the line above okay? It looks okay to me.
$rsBatchRecords = new WA_MySQLi_RS("rsBatchRecords",$siteguide2018,0);
$rsBatchRecords->setQuery("SELECT PORC_records.record_number, PORC_records.sendto_second_round, PORC_records.species_number, PORC_Votes_record_number, PORC_Votes.round1_class, PORC_Votes.round2_class, PORC_Votes.member_name, PORC_Votes.batch_date, PORC_Votes.batch_date2, aou_list.SPNO, aou_list.CommonName
FROM (((PORC_Votes
INNER JOIN PORC_records ON PORC_records.record_number = PORC_Votes.record_number)
INNER JOIN aou_list ON aou_list.SPNO = PORC_records.species_number)
ORDER BY PORC_Votes.record_number");
$rsBatchRecords->bindParam("t", "".(isset($_GET['batch_date'])?$_GET['batch_date']:"") ."", "-1"); //colname
$rsBatchRecords->execute();
Try this:
FROM PORC_Votes
WHERE PORC_Votes.batch_date = ? OR PORC_Votes.batch_date2 = ?
birdscreen398247
Nope. Still get the same error message.
I got rid of the JOINS and replaced it with the following.
$rsBatchRecords->setQuery("SELECT * FROM PORC_Votes, PORC_records, aou_list WHERE PORC_records.record_number = PORC_Votes.record_number AND aou_list.SPNO = PORC_records.species_number AND PORC_Votes.member_name = ? AND (PORC_Votes.batch_date = ? OR PORC_Votes.batch_date2 = ?) ORDER BY PORC_Votes.record_number");
$rsBatchRecords->bindParam("t", "".$_SESSION['MemberName'] ."", "-1"); //colname
$rsBatchRecords->bindParam("t", "".(isset($_GET['batch_date'])?$_GET['batch_date']:"") ."", "-1"); //colname2
$rsBatchRecords->bindParam("t", "".(isset($_GET['batch_date'])?$_GET['batch_date']:"") ."", "-1"); //colname3
I don't get any error messages now, but still no data.
If I remove the "PORC_Votes.member_name = ?" clause, I get data, but for all members. So I assume the problem is in that clause, but I can't figure out what.
Try:
$rsBatchRecords
FROM PORC_Votes
$rsBatchRecords->bindParam("t""".(isset($_GET['batch_date'])?$_GET['batch_date']:"") ."""-1"); //colname
$rsBatchRecords->bindParam("t""".(isset($_GET['batch_date'])?$_GET['batch_date']:"") ."""-1"); //col2name
birdscreen398247
I guess you didn't see my update of the previous reply. The problem is with the membername where clause. See above.
You have:
"t" means "time"... I think that should be an "s" for "string"
birdscreen398247
That did it!
