Index page
Thread begun 11/05/2021 5:38 am by john70964 | Last modified 11/10/2021 2:27 pm by Ray Borduin | 2828 views | 15 replies |
john70964
Index page
I am getting poor results in Google on an index page
Please see PM
This message is about how your analytics are set up, not about the content on your page.
I see you have two <meta name="description" tags... one looks like it isn't very valuable in terms of its content:
<meta name="description" content="JRH ID Proof">
Search engine placement is about keyword targeting, use of valuable words in <title> and <h1> tags and meaningful text covering the topics people are searching for.
It is also about links into your site from other sources, and most reliably it is about paid clicks. You might want to find an SEO expert to help you improve your SEO strategy to attract more visitors. The code for the layout is not the problem.
john70964
Thanks Ray
It was the word clutter which made me think of the content.
Back to work!
John
john70964
Hi Ray,
Working on the same site I found if opened the index page in DW and Pressed F12 I land up on the index page on the Remote server.
I cannot see why that is happening. The live view shows correctly.
In the properties panel the tables are not showing now a few minutes ago they we all showing.
As you can see the definition is showing not correct.
I am attaching some files.
Thanks for any help Ray..
john70964
Hi Ray,
I created another couple of pages which include only a template.
The templates open on the remote server.
These files are attached.
The warning that
Dynamically-related files could not be resolved because the site definition is not correct for this server
keep appearing but I cannot see what is wrong with the settings. Perhaps I should have gone to Spec Saver
I tried to create a new connection in bindings but it failed, message attached.
Regards
John
This is an error related to your Dreamweaver site definition. Not related to your files at all. I'd have to see your site definition settings to potentially spot the issue.
The error in the first screen shot is because you have your connection name set to: conn1_i.php
The connection name should not include the ".php" at the end.
I'm not sure about the preview. I never use that feature, but I imagine it has something to do with bad Server Settings in Dreamweaver. I can see the message in live view warning that there might be an issue.
john70964
Thank for the information Ray.
I am attaching some images of the definitions.
I cannot imagine how when I press preview F12 it can go straight to the remote server, never seen that before!
What version of php are you using? It looks like you are using a MySQL connection, not MySQLi. If you have php7 or newer that would not be compatible with the old MySQL connections.
john70964
I thought I was using mysqli Ray.
Current PHP Version:5.6.32
Thanks Ray
John
