Question about forcing lowercase filenames
Thread begun 9/21/2009 8:18 am by larsentim278054 | Last modified 9/22/2009 12:15 pm by Dani Chankhour | 4452 views | 3 replies |
larsentim278054
I have a couple questions regarding the use of uppercase filenames with your products. Is there any particular reason? For example the images folder is Images, not images? On a unix server, this will not work if using the wrong case (upper or lowercase)...
Anyhow - I decided that to prevent people from typing in the wrong uppercase or lowercase URLS - I was going to switch all the uppercase urls to lowercase, and then in with apache and the .htaccess file - have it force all the urls to use only lowercase. I unfortunately lost the code snippet that allows me to do this. Do you know how to do this? I know you can do it with the help of editing the HTTP CONF file, but I don't have access to that file - I'm on a shared server and they don't allow it. So I would need to do this only with htaccess. I know it's possible, because I've done it before, but I just can't find the code that I used before. Something to do with rewriting [A-Z] to [a-z] but I can't remember the exact syntax.
Anyone know?
Thanks!
Dani Chankhour
There is no reason why we are using uppercase in the file names or folder names. I think it is good practice to always use lowercase.
In regard to your question, please see this link:
force-lower-case-urls-with-mod_rewrite/
larsentim278054
Unfortunately, that only works if you have httpd conf file access which I do not. Is there another way of doing this?
Originally Said By: Dani Chankhour
Dani Chankhour
OK, I found this link that explains how to do it using .htaccess.
index.cgi?area=1153
Look at the fifth post.
