Add to Cart button is adding first item in the recordset rather than the correct item
Thread begun 11/01/2021 2:53 am by Mags | Last modified 11/01/2021 10:32 am by Ray Borduin | 837 views | 2 replies |
Mags
Hi Ray, discovered an issue today and I'm not sure whether it's been triggered by updating the site to mySQLi/PHP7 or when I added a new discount code over the weekend - or it may be that it wasn't working before that and no-one's noticed! Anyway, I have a "Quick Add Softback" button on the attached page which you helped me with before, however when you click it, it adds the first item in the recordset and not the correct item. I'm sure it should be an easy fix but I can't see where the problem is - can you help? Page attached and I've added the URL in a comment at the top if you need it.
It looks like your add to cart button is set up as a "Static Add" instead of "Add from Recordset".
You should be able to open the server behavior and make the adjustment to add from recordset instead and that should add the missing code to make it add the correct record and not the first record.
Mags
That's what the problem was, fixed it now thanks!
