Multiple Update issue
Thread begun 9/28/2021 9:13 am by LWat85283715 | Last modified 10/05/2021 9:34 am by Ray Borduin | 2827 views | 13 replies |
LWat85283715
I have a page that updates multiple records at a time. It sometimes works fine but, sometimes I get this error message:
UPDATE athlete_registrations SET WHERE `registrationID` = ?
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE `registrationID` = ?' at line 1
Here is the my update code:
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) {
$MultipleUpdateConnection = $athletics2;
$MultipleUpdateTable = "athlete_registrations";
$MultipleUpdateRedirect = "edit_office_fields.php?seasonID=".($athlete->getColumnVal("theseason")) ."";
$MultipleUpdateIndexColumn = "registrationID";
$MultipleUpdateIndexColumnType = "d";
$MultipleUpdateIdentifier = "WADA_RepeatID_registrationID";
for ($x=0; $x<sizeof($_POST[$MultipleUpdateIdentifier]); $x++) {
$MultipleUpdateCount = $_POST[$MultipleUpdateIdentifier][$x];
$UpdateQuery = new WA_MySQLi_Query($MultipleUpdateConnection);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = $MultipleUpdateTable;
$UpdateQuery->bindColumn("level4", "s", "".((isset($_POST["level4"."_".$MultipleUpdateCount]))?$_POST["level4"."_".$MultipleUpdateCount]:"") ."", "WA_IGNORE");
$UpdateQuery->bindColumn("physical_date", "t", "".((isset($_POST["physical_date"."_".$MultipleUpdateCount]))?$_POST["physical_date"."_".$MultipleUpdateCount]:"") ."", "WA_IGNORE");
$UpdateQuery->bindColumn("concussion_course2", "t", "".((isset($_POST["concussion_course2"."_".$MultipleUpdateCount]))?$_POST["concussion_course2"."_".$MultipleUpdateCount]:"") ."", "WA_IGNORE");
$UpdateQuery->bindColumn("academic", "s", "".((isset($_POST["academic"."_".$MultipleUpdateCount]))?$_POST["academic"."_".$MultipleUpdateCount]:"") ."", "WA_IGNORE");
$UpdateQuery->bindColumn("impact_testing_date", "t", "".((isset($_POST["impact_testing_date"."_".$MultipleUpdateCount]))?$_POST["impact_testing_date"."_".$MultipleUpdateCount]:"") ."", "WA_IGNORE");
$UpdateQuery->bindColumn("other_medical_info", "s", "".((isset($_POST["other_medical_info"."_".$MultipleUpdateCount]))?$_POST["other_medical_info"."_".$MultipleUpdateCount]:"") ."", "WA_IGNORE");
$UpdateQuery->addFilter($MultipleUpdateIndexColumn, "=", $MultipleUpdateIndexColumnType, $MultipleUpdateCount);
$UpdateQuery->execute();
if ($MultipleUpdateRedirect) {
if (function_exists("rel2abs")) $MultipleUpdateRedirect = rel2abs($MultipleUpdateRedirect,dirname(__FILE__));
header("location: " . $MultipleUpdateRedirect);
Any help would be great. Thanks
Lisa
What version number is listed on the top of your queryobj.php file? I thought this issue was fixed in a previous build.
If you could send me FTP information and a URL to reproduce, then I can debug this for you and figure out what is going on, but it might just need to have that include file updated.
LWat85283715
It is version 2.05. Does this need to be updated?
This is the full code of the page:
<?php require_once('../../Connections/athletics2.php'); ?>
<?php require_once('../../webassist/mysqli/authentication.php'); ?>
<?php require_once('../../webassist/mysqli/rsobj.php'); ?>
<?php require_once('../../webassist/mysqli/queryobj.php');
ini_set('display_errors', 1);
ini_set('display_startup_errors', 1);
error_reporting(E_ALL);
if ("" == "") {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "admins";
$RestricAccessRedirect = "error.php";
if (function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
$athlete = new WA_MySQLi_RS("athlete",$athletics2,0);
$athlete->setQuery("SELECT *, athlete_registrations.athleteID as theathlete, athlete_registrations.seasonID as theseason FROM athlete_registrations left join athletes on athletes.athleteID = athlete_registrations.athleteID left join medication on athlete_registrations.athleteID = medication.athleteID left join sports on athlete_registrations.sportID = sports.sportID WHERE athlete_registrations.seasonID = ? group by athlete_registrations.athleteID order by submitted_date desc");
$athlete->bindParam("i", "".(isset($_GET['seasonID']) ?$_GET['seasonID']:"") ."", "-1"); //colname
$athlete->execute();?>
$season = new WA_MySQLi_RS("season",$athletics2,1);
$season->setQuery("SELECT * FROM season WHERE seasonID = ?");
$season->bindParam("i", "".(isset($_GET['seasonID'])?$_GET['seasonID']:"") ."", "-1"); //colname
$season->execute();
<script src="//code.jquery.com/jquery-1.10.2.js"></script>
<link rel="stylesheet" href="/resources/demos/style.css">
<script src="//code.jquery.com/ui/1.11.4/jquery-ui.js">
</script>
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.1/jquery.min.js"></script>
<script type="text/javascript" src="../lib/site.js"></script>
<!DOCTYPE HTML>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>CRLS Athletic Registration System</title>
<link href="../text_athletics_admin.css" rel="stylesheet" type="text/css">
<style type="text/css">
td img {margin: 0;}
table.sortable th:not(.sorttable_sorted):not(.sorttable_sorted_reverse):not(.sorttable_nosort):after {
content: " \25B4\25BE"
table.sortable tbody tr:nth-child(2n) td {
background: #cccccc;
table.sortable tbody tr:nth-child(2n+1) td {
background: #ccfffff;
</style>
<script src="//code.jquery.com/jquery-1.11.3.min.js"></script>
<script src="https://cdn.datatables.net/1.10.8/js/jquery.dataTables.min.js"></script>
<link rel="stylesheet" type="text/css" href="https://cdn.datatables.net/1.10.8/css/jquery.dataTables.min.css" />
<script type="text/javascript" class="init">
$(document).ready(function() {
$('#example').DataTable( {
"order": [[ 0, "desc" ]]
</script>
body {
background-color: #e8e5de;
</style>
</head>
<body><form method="post">
<div class="container">
<div class="side">
<div class="header">
<h2>CRLS Athletic Registration System</h2>
</div>
<h3><?php echo($season->getColumnVal("season")); ?> Athletes</h3> <form method="post">
<table height="300px" width="100%" border="0" cellspacing="2" cellpadding="8">
<tr>
<td height="10" align="center" valign="middle" bgcolor="#CCCCCC"><a href="manage-sports.php">Manage Sports</a> | <a href="manage_positions.php">Manage Positions</a> | <a href="manage_seasons.php">Manage Seasons</a> | <a href="manage_coaches.php">Manage Coaches</a> | <a href="manage_athletes.php">Manage Athletes</a> | <a href="manage_policies.php">Manage Policies </a> | <a href="change_password.php">Change Your Password</a> | <a href="manage_admin_accounts.php">Manage Admin Accounts</a> | <a href="reports.php">Reports</a></td>
</tr>
<tr>
<td height="10" valign="top" bgcolor="#00A499"><strong><font color="#FFFFFF">Enter the Athlete Info Below
<input type="submit" name="submit" id="submit" value="SAVE DATA">
</font></strong></td>
</tr>
<tr>
<td valign="top" align="center">
<table width="100%" border="0" cellspacing="3" id="example" cellpadding="5" class="display">
<thead>
<tr>
<th valign="top">Submitted Date</th>
<th valign="top">Last Name</th>
<th valign="top">First Name</th>
<th valign="top">Student ID#</th>
<th valign="top">Sport</th>
<th valign="top">Level</th>
<th valign="top">Physical Date</th>
<th valign="top">Concussion Course</th>
<th valign="top">Academic</th>
<th valign="top">IMpact Testing</th>
<th valign="top">Other Medical Info</th>
<th valign="top">&nbsp;</th>
</tr>
</thead>
<tbody>
$wa_repeatfor = -1; // Repeat Selection 1
if (!isset($wa_repeatcount)) $wa_repeatcount = 0;
while (!$athlete->atEnd() && $wa_repeatfor != 0) {
$wa_repeatfor--;
$wa_repeatcount++;
if (!$athlete->atEnd()) {
<tr>
<td valign="top"> <?php echo(date("m/d/Y", strtotime($athlete->getColumnVal("submitted_date")))); ?></td>
<td valign="top"><?php echo($athlete->getColumnVal("student_lname")); ?></td>
<td valign="top"><?php echo($athlete->getColumnVal("student_fname")); ?></td>
<td valign="top"><?php echo($athlete->getColumnVal("studentID")); ?>
<input type="hidden" name="WADA_RepeatID_registrationID[]" id="WADA_RepeatID_registrationID_<?php echo($athlete->getColumnVal("registrationID")); ?>" value="<?php echo($athlete->getColumnVal("registrationID")); ?>" /></td>
<td valign="top"><?php echo($athlete->getColumnVal("sport_name")); ?></td>
<td valign="top"><label for="level4"></label>
<select name="level4_<?php echo($athlete->getColumnVal("registrationID")); ?>" id="level4_<?php echo($athlete->getColumnVal("registrationID")); ?>">
<option value="" <?php if (!(strcmp("", ($athlete->getColumnVal("level4"))))) {echo "selected=\"selected\"";} ?>></option>
<option value="Varsity" <?php if (!(strcmp("Varsity", ($athlete->getColumnVal("level4"))))) {echo "selected=\"selected\"";} ?>>Varsity</option>
<option value="JV" <?php if (!(strcmp("JV", ($athlete->getColumnVal("level4"))))) {echo "selected=\"selected\"";} ?>>JV</option>
<option value="Freshman" <?php if (!(strcmp("Freshman", ($athlete->getColumnVal("level4"))))) {echo "selected=\"selected\"";} ?>>Freshman</option>
</select></td>
<td valign="top"><label for="physical_date"></label> <input name="physical_date_<?php echo($athlete->getColumnVal("registrationID")); ?>" type="date" id="physical_date_<?php echo($athlete->getColumnVal("registrationID")); ?>" value="<?php echo($athlete->getColumnVal("physical_date")); ?>"></td></td>
<td valign="top"><label for="concussion_course2"></label>
<input name="concussion_course2_<?php echo($athlete->getColumnVal("registrationID")); ?>" type="date" id="concussion_course2_<?php echo($athlete->getColumnVal("registrationID")); ?>" value="<?php echo($athlete->getColumnVal("concussion_course2")); ?>"></td>
<td valign="top"><label for="academic"></label>
<input name="academic_<?php echo($athlete->getColumnVal("registrationID")); ?>" type="text" id="academic_<?php echo($athlete->getColumnVal("registrationID")); ?>" value="<?php echo($athlete->getColumnVal("academic")); ?>"></td>
<td valign="top"><label for="impact_testing_date"></label>
<input name="impact_testing_date_<?php echo($athlete->getColumnVal("registrationID")); ?>" type="date" id="impact_testing_date_<?php echo($athlete->getColumnVal("registrationID")); ?>" value="<?php echo($athlete->getColumnVal("impact_testing_date")); ?>"></td>
<td valign="top"><label for="other_medical_info"></label>
if ("".($athlete->getColumnVal("medical_comments")) ."" > "0") { // WebAssist Show If
<br><?php echo($athlete->getColumnVal("medical_comments")); ?>
} // ("".($athlete->getColumnVal("medical_comments")) ."" > "0")
if ("".($athlete->getColumnVal("medical_conditions_comments")) ."" > "0") { // WebAssist Show If
<br><?php echo($athlete->getColumnVal("medical_conditions_comments")); ?>
} // ("".($athlete->getColumnVal("medical_conditions_comments")) ."" > "0")
if ("".($athlete->getColumnVal("serious_conditions_comments")) ."" > "0") { // WebAssist Show If
<br><?php echo($athlete->getColumnVal("serious_conditions_comments")); ?>
} // ("".($athlete->getColumnVal("serious_conditions_comments")) ."" > "0")
if ("".($athlete->getColumnVal("traumatic_head_injury_comments")) ."" > "0") { // WebAssist Show If
<br><?php echo($athlete->getColumnVal("traumatic_head_injury_comments")); ?>
} // ("".($athlete->getColumnVal("traumatic_head_injury_comments")) ."" > "0")
<br><?php echo($athlete->getColumnVal("medical_attention_comments")); ?>
<br><?php
if ("".($athlete->getColumnVal("concussion_comments")) ."" > "0") { // WebAssist Show If
<?php echo($athlete->getColumnVal("concussion_comments")); ?>
} // ("".($athlete->getColumnVal("concussion_comments")) ."" > "0")
<textarea name="other_medical_info_<?php echo($athlete->getColumnVal("registrationID")); ?>" id="other_medical_info_<?php echo($athlete->getColumnVal("registrationID")); ?>" cols="30" rows="3"><?php echo($athlete->getColumnVal("other_medical_info")); ?></textarea></td>
<td align="right" valign="top"><font size="-1"><a href="view_athlete_registration.php?athleteID=<?php echo($athlete->getColumnVal("theathlete")); ?>&registrationID=<?php echo($athlete->getColumnVal("registrationID")); ?>&seasonID=<?php echo((isset($_GET["seasonID"]))?$_GET["seasonID"]:"") ?>">View</a>
if ("".(($athlete->getColumnVal("no_meds"))) ."" == NULL ) { // WebAssist Show If
<br>
<a href="view_athlete_registration.php?athleteID=<?php echo($athlete->getColumnVal("theathlete")); ?>&registrationID=<?php echo($athlete->getColumnVal("registrationID")); ?>&seasonID=<?php echo((isset($_GET["seasonID"]))?$_GET["seasonID"]:"") ?>"><img src="../images/med.png" alt="Takes Meds" width="36" height="39" border="0"></a>
} // ("".(($athlete->getColumnVal("no_meds"))) ."" == NULL")
</font></td>
</tr>
$athlete->moveNext(); // Repeat Alternate 1
} else {
} // End Repeat Alternate 1
if (!isset($wa_startindex)) $athlete->moveFirst(); // End Repeat Selection 1
</tbody>
</table>
</td>
</tr>
</table>
<div class="header"><p align="center"><font color="#FFFFFF">Cambridge Rindge & Latin School | <a href="http://crls.cpsd.us" target="_blank"><font color="#FFFFFF">crls.cpsd.us</font></a> | 617.349.6690</font></p></div>
</div>
</div></form>
</body>
</html>
The current version is 2.31, so that is probably the problem. Please try reinstalling databridge and re-applying the update server behavior. That should update the file that you can then upload to the server and try again.
LWat85283715
How do I obtain the newest file to update DataBridge?
Just reinstall from your My Account page on the webassist site.
LWat85283715
When I downloaded the MySQLI Server Behaviors, the multiple update behavior is not the in the list.
DataBridge... not MySQLi Server Behaviors.
Reinstall DataBridge. It has additional functionality not included in the MySQLi Server Behaviors.
LWat85283715
Hmm. I don't see that under my downloads. I think I have the functionality from when you were doing beta testing and gave it for free.
That is possible.... Well you should still be able to update the queryobj.php file from mysqli server behaviors. Just create a test page and apply an insert, update, or delete server behavior and it should re-create that file. Then upload it.
