Checkout failure removes the items from the cart. How do I keep?
Thread begun 9/15/2021 10:41 am by lr_leal239405 | Last modified 9/18/2021 5:10 pm by Ray Borduin | 895 views | 2 replies |
lr_leal239405
I would like to keep the items in the cart on checkout failure so that the client can try again by going to the cart. Where do I make code change?
Thanks!
Checkout failure should not remove the items from the cart. Maybe you are changing urls on checkout failure to add or remove www from the url? Maybe you have a clear cart on the failure page? By default, a failed checkout would not clear the cart, so I'd have to dig into why that is happening.
lr_leal239405
It was the not using the www in the link. After fixing that, they Do remain in the cart. Thanks.
