PHP jQuery File Upload
Thread begun 8/31/2021 10:30 am by Daniel | Last modified 9/01/2021 9:36 am by Ray Borduin | 595 views | 2 replies |
Daniel
Good Day,
I'm doing a multiple file upload with jQuery.
Here is the code:
1. jqueryFileUpload.php page:
$("#submit-button").click(function() {
var formData = new FormData();
var file = $("#file")[0].files[0];
var fileTwo = $("#fileTwo")[0].files[0];
var fileThree = $("#fileThree")[0].files[0];
formData.append('file', file);
formData.append('fileTwo', fileTwo);
formData.append('fileThree', fileThree);
$.ajax({
url: 'jqueryFileUploadB.php',
type: 'post',
data: formData,
contentType: false,
processData: false,
success: function(data){
alert('Successful jQuery file upload to: ' + data)
$("#jquery-upload-form")[0].reset();
2. jqueryFileUploadB.php page:
require_once("webassist/file_manipulation/helperphp.php");
if (isset($_FILES['file']['name'])) {
$uploadOne = move_uploaded_file($_FILES['file']['tmp_name']);
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "images/",
'FileName' => "".$_FILES['file']['name']."",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
WA_DFP_UploadFiles("WA_UploadResult1", $_FILES['file']['tmp_name'], "2", "[NewFileName]_[Increment]", "false", $WA_UploadResult1_Params);
What PHP should change on the 'jqueryFileUploadB.php' page for the file to upload like it normally would if the PHP runs on the same page as the form?
Thank you.
I don't really understand your question. Does it all work now, you just want to change the page that it works on? It looks like you have 3 files uploading, but only 1 is accounted for in the server code. Does the first one work and not the other two?
I need to understand what exactly is and isn't working and what your question is exactly before I can attempt to answer.
Daniel
Ray thank you for responding.
In the process since yesterday I managed to get it right.
What I meant with the question was:
Yes I did want the form to function on another page without going to the other page and without like a page refresh when the form submits but I managed to make it operate with jQuery.
Thank you for your help.
