Dynamically-related files could not be resolved because of an internal server error.
Thread begun 8/20/2021 8:15 am by birdscreen398247 | Last modified 8/21/2021 1:04 pm by Ray Borduin | 1115 views | 2 replies |
birdscreen398247
I am getting the above error message on several of my files.
I reinstalled the latest DataBridge (2.3.5)
I can't figure out the problem.
See the attached file.
I think that is a site settings issue in Dreamweaver and not related to the file you are viewing itself. Most likely you haven't set up your testing server correctly or it has a bad URL setting.
birdscreen398247
I discovered the problem.
The SecurityAssist link was after the SecurityAssist function.
I moved it up top and everything works.
