Sudden checkout failure
Thread begun 8/19/2021 5:05 am by rob75685 | Last modified 8/23/2021 9:19 am by Ray Borduin | 1919 views | 6 replies |
rob75685
hi there
I'm suddenly getting checkout failure on a site that's been running for a few years. Connecting to PayPal
The website is : https://davidhayward.com/
I can add a product to the cart, complete the checkout page but then it just hangs for ages then goes to the checkout failure page...
Could someone take a look please?... maybe the PayPal API has changed?...
thanks so much
Add this to the top of the checkout failure page:
@session_start();
var_dump($_SESSION);
die();
Then send me the result after using view source so it is better formatted. I should be able to spot the error there and let you know what needs to be done.
rob75685
source
thanks so much Ray!
Here you go: (in private area)
You aren't getting a result from Paypal at all... That usually means a curl configuration issue on the server. I'd need FTP access to debug this further, but my best guess is that it is an issue with curl somehow.
rob75685
thanks Ray - FTP details attached privately
It looks like you had an old version of /WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php
It had an old endpoint for the paypal API that doesn't work anymore. I updated that file and it appears to have fixed that issue.
rob75685
thank you!
Thank you so much Ray, awesome support!
