Symbols change to "?" marks when updating content in PowerCMS2?
Thread begun 8/14/2021 9:13 pm by cldsk | Last modified 8/17/2021 7:36 am by Ray Borduin | 1594 views | 5 replies |
cldsk
I have a page that uses the diamond symbol. In the "Source" I added the ♦ to get the symbol. It shows. But when I go back and update the content all the diamonds become "?".
How do I prevent this from happening? Thanks!
cldsk
In the actually CMS the source also switched it out to "?" I just redid them all again. Not sure what would cause this?
cldsk
This definitely seems like a PowerCMS issue, everytime I make a change all the symbols revert back to question marks, both in the site, the PowerCMS preview, and the PowerCMS source code. I have tried using both the html code and the hex code for the symbols.
I have redone these symbols about 5 times now - an there are a ton of symbols so definitely would love for PowerCMS to keep them in place!
thank you for any help on this!
It looks like the default charset in the database is set to latin1. Try changing the pcms2_contents table and specifically the ContentValue column to utf8. You can change the collation to: utf8_unicode_ci
cldsk
Thanks so much the collation was set to: latin1_swedish_ci (same with others - not sure if this would pose a problem for any content in the other columns?). Changing it to utf8_unicode_ci did seem to solve the problem! Definitely appreciate it! Do you know if this was a problem with how the database was written by PowerCMS on install, or is it an issue with the hosting environment? Just wanted to know if it is something I should manual change with future installs? Thanks!
It appears to be an issue with the power cms database creation script. I have updated the .zip file to include the utf8 charset definition. It probably won't be an issue for other columns since they wouldn't likely contain special characters like the content value.
