Using a Theme with DW cs6
Thread begun 8/13/2021 2:29 pm by john70964 | Last modified 8/21/2021 1:03 pm by Ray Borduin | 1051 views | 3 replies |
john70964
I am trying to use an Evanto theme in Dreamweaver cs6
I have setup the normal setup and server files for testing but I get the warning note in Dreamweaver top line that the site defintion is not correct.
In the top directory there is a config.php file and I suspect that is the connection and I have entered the database details..
As a test I removed the server details from the dreamweaver set up this caused the url to appear as file:///C:/xampp/htdocs/xxx-wp/index.php
The code for the index page is
define( 'WP_USE_THEMES', true );
/** Loads the WordPress Environment and Template */
require __DIR__ . '/wp-blog-header.php';
I wondered if you can see where this is going wrong please?
John
You might want to find a wordpress forum for this question since it is directly related to wordpress and not to our extensions. I could probably figure this out with a lot of debugging and direct access to the code, but I don't regularly use wordpress, so I couldn't help without digging in more and taking some time looking into it.
john70964
Thanks Ray,
I will follow that path.
Regards
John
john70964
Hi Ray
I have looked at several different word press offerings and a strange factor is that when they are displayed in htdocs any php page shows as a Dreamweaver icon and if I double click the icon it tries to open Dreamweaver.
Regards
John
