Nested Repeat Regions
Thread begun 8/13/2021 12:12 pm by birdscreen398247 | Last modified 8/16/2021 11:05 am by Ray Borduin | 895 views | 2 replies |
birdscreen398247
I am having trouble with nesting repeat regions.
I read all of the threads on this, but still cannot get it right.
I am trying to nest a table within another table.
See attached file.
You have:
CountArea = ? AND Count? = ? ORDER BY Count?
but you only have one parameter:
$rsLists->bindParam("i", "".($rsCounty->getColumnVal("CountyName")) ."", "a"); //County
Do you have a question mark in your column name? I'd remove that if possible, since question marks are used for placeholders for parameters and special characters in column names can cause issues in general.
The number of question marks in your SQL statement should be the same as the number of bindParam() statements below that replace the question marks with dynamic values.
birdscreen398247
I must have sent you the wrong version of the file.
I have since gotten it to work.
