How do I remove table fields using the SecurityAssist GUI
Thread begun 8/11/2021 10:29 am by randyrie405335 | Last modified 8/12/2021 9:57 am by Ray Borduin | 846 views | 3 replies |
randyrie405335
Is there a way to control which fields the WA Security Assist GUI inserts into the pcm2_users table? Are these preset and only removed via the MySQL dB manager?
You would have to remove them using phpMyAdmin.
randyrie405335
Remove Tables
Will doing so have any adverse affects on the security suite?
No, you can remove any columns you aren't using. It is just a sample database.
