Sql error
Thread begun 8/09/2021 12:17 pm by birdscreen398247 | Last modified 8/09/2021 1:57 pm by Ray Borduin | 499 views | 1 replies |
birdscreen398247
Sql error
I am trying to create cascading dropdown lists based on sqli data.
When I try to run the page, I get "There is an error in your SQL syntax."
But it doesn't tell me what the error is.
Both sqli recordsets created using Msqyli in WebAssist
See attached file for my code.
line 10 you have:
$rsLists->setQuery("SELECT DISTINCT FullName, CountType, CountArea, FullName, CONCAT(CountType, " - ", CountArea) AS CountDef FROM birdlists WHERE FullName=? ORDER BY CountType, CountArea");
it should be:
$rsLists->setQuery("SELECT DISTINCT FullName, CountType, CountArea, FullName, CONCAT(CountType, ' - ', CountArea) AS CountDef FROM birdlists WHERE FullName=? ORDER BY CountType, CountArea");
To get the full error you can open up rsobj.php and turn on debug mode.... where it says ->Debug = false; on the top of the page, change it to "true".
