I need to add an If statement before inserting a record
Thread begun 8/09/2021 8:10 am by birdscreen398247 | Last modified 8/09/2021 1:55 pm by Ray Borduin | 633 views | 1 replies |
birdscreen398247
I have an Insert Form that adds records to two tables.
The first insert query adds a record to PORC_records and captures the ID field.
I then have multiple fields on the form (Link1, Link2, Link3, etc.) which I want to add to the PORC_ebirdlinks table using the ID captured above and the contents of Link1, Link2, etc.
Each of those form fields will create a new record. So Link1 will be a record, Link2 will be a record, etc.
However, not all of those fields will have data, so I want an "if not null" type of condition before each of those insert queries.
I know the algorithm, just not the syntax for the coding.
I have only put two "Link" Insert Queries in so far. I will add the others once I have the "If" coding.
See attached code.
I think something like this would work for you:
if (isset($_POST["submit"])) {
$InsertQuery = new WA_MySQLi_Query($siteguide2018);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "PORC_records";
$InsertQuery->bindColumn("common_name", "s", "".((isset($_POST["species"]))?$_POST["species"]:"")  ."", "WA_DEFAULT");
$InsertQuery->saveInSession("ID");
$InsertQuery->execute();
$InsertGoTo = "";
  if (
function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
if ((isset($_POST["link1"]))?$_POST["link1"]:"") {
$InsertQuery->Table = "PORC_ebirdlinks";
$InsertQuery->bindColumn("record_ID", "s", "".($_SESSION["ID"])  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("ebird_link", "s", "".((isset($_POST["link1"]))?$_POST["link1"]:"")  ."", "WA_DEFAULT");
$InsertGoTo = "";
  if (
if ((isset($_POST["link2"]))?$_POST["link2"]:"") {
$InsertQuery->bindColumn("ebird_link", "s", "".((isset($_POST["link2"]))?$_POST["link2"]:"")  ."", "WA_DEFAULT");
$InsertGoTo = "";
  if (
