Problem with one of the pages in eCart
Thread begun 8/06/2021 5:54 am by NWak04030229 | Last modified 8/12/2021 9:58 am by Ray Borduin | 2850 views | 11 replies |
NWak04030229
I have a problem with one page of my website in which the script for the cart does not enter correctly - a rogue <td> I have attached the screenshot of the problem but can give you access to the ftp to see the whole page script if required
It looks like it removed the </td> tag when the cart was entered. Try just adding it back after the </form> tag manually.
NWak04030229
I did insert it manually but every time I put a new item on this page it does exactly the same thing so am having to manually insert after each item I put on the page - other pages are absolutely fine
It may have something to do with the other html on the page. If you send me a copy of the page I can see if I can reproduce the issue and debug it.
NWak04030229
That's odd... I was able to add a button without experiencing the issue you described. Are you adding from design view or code view? What version of Dreamweaver are you using? Mac or PC?
NWak04030229
I am adding from design view with code view underneath so I can check on it. I am using Dreamweaver CC 20.2 Build 15263 on Windows 10 Pro
I'm using Dreamweaver 21.1 build 15413 on Windows 10 Pro. That may be the difference.
It is possible I'm doing something differently than you when I add the buttons too. What exactly are you clicking on and what are you using to add the code. If I can reproduce it, then I can usually fix it, but so far I haven't been able to see the issue.
NWak04030229
I've done a screenshot of the process but can't send here as attachment for some reason
If you want to call me at the office tomorrow I can do a screen share and debug it on your computer since I can't seem to reproduce it here.
