/webassist/framework/ajax_wrapper.php - Framework file not found:
Thread begun 7/29/2021 6:29 pm by Rokon | Last modified 7/29/2021 10:13 pm by Ray Borduin | 607 views | 2 replies |
Rokon
Hello
I have two page where a dynamic table list is loading to index.php from external page userlist.php
on the userlist.php I have edit and delete function included there.
Now normally on the index.php page the content of the userlist.php is showing without any problem but when I am tyring to delete anyting then the error coming and show Framework file not found: and on the url it is showing /webassist/framework/ajax_wrapper.php
The same function when I try on my localhost then it does not show that error and the delete function works without any problem, pls help. I am attaching both the file here for your easy ref.
Update
I found that when I filter the record from index.php page and try to delete then the delete function does not work and show this Framework file not found: error but if I go to that record by using navigation and delete that time it delete the record and no error shows.
In practical I need to make filter and then delete the particular record and that is the part where it is not functioning and throwing this error. Pls help.
I may need a url and FTP access to debug this one... You might try updating line 140 of userlist.php from:
<form action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]);?>" method="post" enctype="multipart/form-data" id="deluser">
<form action="userlist.php" method="post" id="deluser">
Rokon
Yes you are right, before I see your reply I just removed that part to just <form method="post" enctype="multipart/form-data" id="deluser"> tried on the server and it workd! I was confused that it was working on localhost and not on the remote server and for this reason it took longer for me to figure out the problem. Thank a lot.
