Images not showing
Thread begun 7/22/2021 10:09 pm by john70964 | Last modified 7/26/2021 10:33 am by Ray Borduin | 2669 views | 9 replies |
john70964
Images not showing
Hello
I have an index page which suddenly in Dreamweaver is not showing the images.
It was working in DW up until yesterday and this morning for some reason I cannot see the pictures only links.
I have checked that all images are in the correct folder.
If I select Design and Live the the images show correctly.
I wondered if you can see any reason for this?
I am attaching the files
john
I don't see why that would happen. I'd probably have to view it in a browser to be able to debug it properly. Try right-clicking on the image and view the image directly to see if there is an issue with the path.
john70964
Hi Ray
Please see PM
Are you sure you have all of the images downloaded on your localhost? I'd have to set up screen sharing to debug it with you, but it seems the most likely cause would be you haven't downloaded all of those images from the live server.
john70964
Thanks Ray,
I am attaching a text document showing the records that my test shows on the home page
I have carefully recorded this information from the local files and am very sure the information is correct
I'll need to set up a screen sharing session in order to debug this. I won't be able to figure it out without active debugging.
john70964
Thanks Ray,
Is Monday or Tuesday next week good for you?
Yes. Just give me a call on monday using the number at the bottom of every page of this site and we can work out a good time.
john70964
Thanks Ray,
As the remote index.php page is working correctly I thought the problem may be solved by downloading this..
I renamed my local index.php and downloaded and used the page from the remote server.
The result is the same error is occurring so it seem the error must be outside of the index page.
BTW what s the best time GMT to call?
You can call me anytime. I'm often here 9-5pst. That is 4pm-12am GMT.
It looks like you manually created that connection file and the connection isn't referring to the variables set properly.
You have:
$conn1_i = mysqli_connect($localhost, $username, $password, $database);
but I think it should be:
$conn1_i = mysqli_connect($hostname_conn1_i, $username_conn1_i, $password_conn1_i, $database_conn1_i);
