Incorporating AJAX into DA results page
Thread begun 7/22/2021 7:50 am by Mags | Last modified 7/22/2021 2:25 pm by Ray Borduin | 1207 views | 3 replies |
Mags
Hi Ray, I use the DataTables plugin to add instant filtering and data search options to a DA results page. The database has over 4,000 entries and it's taking DataTables around 16 seconds to load because of this. They do offer an additional parameter to allow server-side processing using AJAX but I'm not sure how to implement this on my page, but I know nothing about AJAX! I noticed you do have an example of using AJAX in one of your tutorials, so I wondered if this is something you could help me with? I've attached a copy of the page as it is currently and the DataTables documentation gives the following example of how to add server-side processing to speed up load times:
$(document).ready(function() {
$('#example').DataTable( {
"processing": true,
"serverSide": true,
"ajax": "../server_side/scripts/server_processing.php"
I could probably help. I haven't done it before with data tables, but I'm sure I could follow the documentation. I could also help with a webassist solution that might be more efficient, but might not be as easy to finish since you have the page mostly working.
If you want to set up a premier support ticket then I could definitely help in a screen sharing session.
Mags
That sounds good, happy to do a premier support ticket - let me know when would be good for you. In the meantime, here's a link to the DataTables page with some sample code which will hopefully help: https://datatables.net/examples/data_sources/server_side.html
Just call me at the main webassist number at the bottom of every page of this site and we can work out a time.
