Problem with Mysqli show region utility and page navigation
Thread begun 7/21/2021 1:26 am by Rokon | Last modified 7/26/2021 10:33 am by Ray Borduin | 3225 views | 16 replies |
Rokon
Hello
I have a page where I put the repeat region inside a conditional mysqli show region utilty so that if the user level is admin then that repeat region portion should show, but the problem comes when in order to navigate the record I hit the next page like pageNum_userList=1&totalRows_userList=28 then all become blank and nothings shows.
Example
- /user/Index.php - this is my main page
- I put repeat region of all the users in this page and per page 10 record should show
- I put show conditional region so that if a user level is admin then this repeat region part should be visible
So normally the 1st page is showing 10 record without any problem if the user level is admin, but when I am clicking to next page (pageNum_userList=1&totalRows_userList=28) then nothing is visible anymore, I am not sure what it is causing the problem. please help me.
<?php require_once('../../webassist/framework/framework.php'); ?>
require_once('../../webassist/framework/library.php'); ?>
require_once('../../Connections/hadithbd.php'); ?>
require_once('../../webassist/mysqli/rsobj.php'); ?>
require_once('../../webassist/mysqli/queryobj.php'); ?>
require_once('../../webassist/mysqli/authentication.php'); ?>
if (true) {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action "restrict";
$RestrictAccess->Name "LoggedIn";
$RestricAccessRedirect "login.php";
  if (
function_exists("rel2abs")) $RestricAccessRedirect $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect $RestricAccessRedirect;
$RestrictAccess->execute();
if (isset($_POST["deluser"]) || isset($_POST["deluser_x"])) {
$DeleteQuery = new WA_MySQLi_Query($hadithbd);
$DeleteQuery->Action "delete";
$DeleteQuery->Table "users";
$DeleteQuery->addFilter("UserID""=""i""".((isset($_POST["userid"]))?$_POST["userid"]:"")  ."");
$DeleteQuery->execute();
$DeleteGoTo "../done.php";
  if (
function_exists("rel2abs")) $DeleteGoTo $DeleteGoTo?rel2abs($DeleteGoTo,dirname(__FILE__)):"";
$DeleteQuery->redirect($DeleteGoTo);
$userList
= new WA_MySQLi_RS("userList",$hadithbd,10);
$userList->setQuery("SELECT users.* FROM users ORDER BY users.UserID ASC");
$userList->execute();
if("" == ""){
$WA_hadithbd_template_1626822995751_Content_Empty "";
$WA_hadithbd_template_1626822995751_Content = new WA_Include(__FILE__);
$WA_hadithbd_template_1626822995751_Template = new WA_Include("../../Templates{$WA_hadithbd_template_1626822995751_Content_Empty}/hadithbd-template.dwt.php");
    require(
$WA_hadithbd_template_1626822995751_Template->BaseName);
$WA_hadithbd_template_1626822995751_Template->Initialize(true);
<!doctype html>
<html lang="bn"><!-- InstanceBegin template="/Templates/Themes/hadithbd-template_fw_theme.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no">
<!-- InstanceBeginEditable name="doctitle" -->
<!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="head" -->
</head>
<body>
<!-- InstanceBeginEditable name="Main-body-area" -->
    <main>
if ("".($userList->getColumnVal("userLevel"))  ."" == "10") {  // WebAssist Show If
      <div class="container  mt-4 mb-5">
        <div class="card bg-light shadow">
          <div class="card-header shadow h4">User Info</div>
          <div class="card-body">
            <h5 class="card-title">Light card title</h5>
            <div class="card-text">
              <table class="table">
                <thead class="thead-dark">
                  <tr>
                    <th scope="col">User#</th>
                    <th scope="col">Full Name</th>
                    <th scope="col">Signup</th>
                    <th scope="col">E-Mail</th>
                    <th scope="col">Level</th>
                    <th scope="col">Status</th>
                    <th scope="col">Action</th>
                  </tr>
                </thead>
                <tbody>
$wa_startindex
0;
while(!
$userList->atEnd()) {
$wa_startindex $userList->Index;
                    <tr>
                      <td><?php echo($userList->getColumnVal("UserID")); ?></td>
                      <td><?php echo($userList->getColumnVal("UserFullName")); ?></td>
                      <td><?php echo($userList->getColumnVal("UserRegistrationDate")); ?></td>
                      <td><?php echo($userList->getColumnVal("UserEmail")); ?></td>
                      <td><?php
                          <i class="fas fa-crown text-warning"> </i>
// ("".($userList->getColumnVal("userLevel"))  ."" == "10")
if ("".($userList->getColumnVal("userLevel"))  ."" == "2") {  // WebAssist Show If
                          <i class="fas fa-user-graduate text-success"></i>
if ("".($userList->getColumnVal("userLevel"))  ."" == "1") {  // WebAssist Show If
                          <i class="fas fa-user text-primary"></i>
if ("".($userList->getColumnVal("userLevel"))  ."" == "0") {  // WebAssist Show If
                          <i class="fas fa-user text-danger"></i>
?></td>
                      <td><?php
if ("".($userList->getColumnVal("userActive"))  ."" == "1") {  // WebAssist Show If
                          <i class="fas fa-user-check text-success"></i>
                          <?php }else{ ?>
                          <i class="fas fa-user-times text-danger"></i>
// ("".($userList->getColumnVal("userActive"))  ."" == "1")
?></td>
                      <td><?php
if ("".($userList->getColumnVal("userLevel"))  ."" != "10") {  // WebAssist Show If
                          <div class="form-row">
                            <div class="form-group mr-1">
                              <form  action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]);?>" method="post" enctype="multipart/form-data" id="edituser">
                                <button name="edituser" class="btn btn-warning" role="button" data-toggle="tooltip" data-html="true" title="এই একাউন্ট সংশোধন করুন"><i class="fas fa-user-edit"></i></button>
                                <input name="userid" type="hidden" id="userid" value="<?php echo($userList->getColumnVal("UserID")); ?>">
                              </form>
                            </div>
                            <div class="form-group">
                              <form  action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]);?>" method="post" enctype="multipart/form-data" id="deluser">
                                <button name="deluser" onclick="return confirm('আপনি কি মুছে ফেলতে চান?')" class="btn btn-danger" role="button" data-toggle="tooltip" data-html="true" title="এই একাউন্ট মুছে ফেলুন"><i class="fas fa-user-slash"></i></button>
                              </form>
                            </div>
                        </div>
// ("".($userList->getColumnVal("userLevel"))  ."" != "10")
?></td>
                    </tr>
  $userList
->moveNext();
$userList->moveFirst(); //return RS to first record
unset($wa_startindex);
unset(
$wa_repeatcount);
                </tbody>
              </table>
  $rs
$userList// recordset name
require_once("../../navigation/page-navigation.php");
            </div>
          </div>
        </div>
      </div>
    </main>
</body>
<!-- InstanceEnd --></html>
if(isset($WA_hadithbd_template_1626822995751_Template)){
$WA_hadithbd_template_1626822995751_Content->Initialize();
$WA_hadithbd_template_1626822995751_Template->ReplaceTemplateRegions($WA_hadithbd_template_1626822995751_Content);
    print(
$WA_hadithbd_template_1626822995751_Template->Content);
The issue is probably on the page:
I'm probably going to need a url to see the issue and FTP access to debug this one.
Rokon
This post has been deleted.
What is the website url and steps to get to the page including usernames and passwords if necessary?
Rokon
The FTP information provided doesn't seem to be working for me.
Rokon
Still no luck with that FTP information. Maybe you have IP address restrictions in place?
Rokon
I have no idea what's going on. Anyhow I am attaching the both file here in PM.
You have the entire page wrapped in the code:
That checks the first row of the results and would only show if it equals 10, otherwise the entire page won't show.
I'm not sure what you were going for with that line, but I think you should remove lines 59-61 and 168-170
