Cart.php run update with Javascript instead of waiting for Submit form
Thread begun 7/14/2021 7:17 am by lr_leal239405 | Last modified 7/14/2021 2:40 pm by Ray Borduin | 852 views | 2 replies |
lr_leal239405
Cart.php run Quantity updates with Javascript instead of waiting for Update Button pressed
We had an incident where the client said he had changed quantities when adding to cart (in the cart.php page). However, he probably didn't press the 'Update' button so he ended up ordering one of each.
I would like to get rid of the Update button and just have the function below just execute with Javascript onKeyUp: Your help is appreciated. I have attached the cart.php file in case that helps. Thank you.
// WA eCart Update
if (isset($_POST["eCart1_Update_100"]) || isset($_POST["eCart1_Update_100_x"])) {
$eCart1->CartUpdate();
$Redirect_redirStr="";
if ($Redirect_redirStr != "") {
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "Update";
Just add this after line 71:
That way it will update when they press the checkout button as well and you can solve the problem without adding the keypress event.
lr_leal239405
Thanks. That works!
