Turning off display of zero or 0.00
Thread begun 7/12/2021 12:59 pm by dhagood355349 | Last modified 7/22/2021 12:15 pm by Ray Borduin | 3067 views | 16 replies |
dhagood355349
I looked through the older replies here, didn't see this, maybe different in mysqli now.
So I have repeated regions created with databridge. Is there a way to turn off the display of 0 or 0.00 in these tables?
Just add an IF statement to not display it. I'd need specifics to give the exact code.
dhagood355349
Zero
See private
What do you want not displayed if the value is zero?
dhagood355349
Zero to blank
empty field, blank
<?php echo($WADAAFTDirResult->getColumnVal("Final_Weight")?$WADAAFTDirResult->getColumnVal("Final_Weight"):""); ?>
dhagood355349
Zero to blank
So that makes any value show as blank. Some fields from the SQL db would have values greater than 0.00. Example 5.02. It is the ones that are 0 or 0.00 that I would like not to show in the repeating tables.
That should only make values that are zero show blank. I'd need FTP access to debug, or at I'd at least need to see the code to make sure it was added correctly.
dhagood355349
Zero to blank
See Private
That may be a text field in your database. I had to convert it to a number for the comparison to work... This seems to do the trick:
<?php echo(floatval($WADAAFTDirResult->getColumnVal("Final_Weight")) > 0?$WADAAFTDirResult->getColumnVal("Final_Weight"):""); ?>
