Update Record not working
Thread begun 7/02/2021 8:57 am by birdscreen398247 | Last modified 7/02/2021 2:32 pm by Ray Borduin | 1022 views | 3 replies |
birdscreen398247
I created a simple MySQLi/Data Management/Update Record.
When I click on Submit, it returns to the GoTo page, but doesn't save any of the changes.
No error messages.
See attached file.
You have your update set up to update from the recordset instead of updating from the form. That wouldn't change the value. Change your update server behavior to use the form values instead of recordset values on update.
birdscreen398247
I made that change and now I get "incorrect INTEGER value: " when I click on Submit.
The PORC_Active is a checkbox value. Set it to "Checkbox 1/0" instead of "integer" for the value binding. Also set the value of the <input> to value="1" and use the Dynamic button in the properties window to set the checked status based on the database value.
