MySqli Insert Record not working
Thread begun 7/01/2021 1:23 pm by birdscreen398247 | Last modified 9/26/2022 10:19 am by Ray Borduin | 2412 views | 14 replies |
birdscreen398247
I created a page to insert a new record in my database using MySqli/data Management/Insert Record.
I chose "Submit on this form"
There are no validations to deal with, just plain entries.
When I click Submit, it blanks the form, does not insert the record, nor go to the $InsertGoTo page
See attached file.
Your insert runs on form post, but your form method is type get.
I'd add mehod="post" to your form tag and then find replace $_GET for $_POST in your code and that should fix it.
DeanCollins
I'm also having a problem with the mysqli insert record. II'm testing this on one form field only (Site Name). I've used the form field in the column bindings tab. Nothing is required in the current form. I've attached the page.
Your form action is set to: action="forms.php"
But your insert code is on forms_application.php. Your form action has to point to the page with the insert code. You can add a redirect to go to the other page after the insert has completed.
DeanCollins
Thanks! Changing the action to forms_application.php fixed part of the problem. A record now inserts, but the record is blank, it doesn't insert anything.
Is there something wrong with my form field?
<label class="form-label mb-0">Name or Description of Site:</label>
<input type="text" class="form-control" name="si_site">
I don't see anything wrong. Please attach the page again and I'll take a look.
DeanCollins
It's attached. I've added a couple more bindings so I could test the upload behavior (it doesn't work).
You have your bindings set up to insert from the recordset instead of insert from the form.
Your file upload should be bound to the "Server File Name" value from the file upload. Also your upload Trigger should be the same as your insert trigger.
I could help you with something like this in a premier support ticket for $100/hr. This would probably only take 10 minutes, but there is a $50 minimum.
DeanCollins
Thanks! I thought I'd tried binding to the form. Guess not. So, that works now. However, the upload still doesn't work.I have many "Database > Dataassist Pages" with file uploads. Never had any problem with those.
Anyway, where do I put in a Premier Support ticket?
You can just call the number at the bottom of every page on this website and we can coordinate a time to meet. If you attached the most recent version of the page then I could try to help here as well.
