eCart not connecting
Thread begun 6/23/2021 11:51 am by NWak04030229 | Last modified 6/23/2021 3:05 pm by Ray Borduin | 1571 views | 4 replies |
NWak04030229
I have put a couple of new pages on my website and I cannot get ecart to connect for some reason. The code on the page is:
//WA eCart Include
require_once("../WA_eCart/UsedMagic_PHP.php");
$UsedMagic->GetContent();
// WA eCart AddToCart
if (isset($_POST["UsedMagic_1_ATC"]) || isset($_POST["UsedMagic_1_ATC_x"])) {
$ATC_itemID = $_POST["UsedMagic_1_ID_Add"];
$ATC_AddIfIn = 1;
$ATC_RedirectAfter = "cart.php";
$ATC_RedirectIfIn = "";
$ATC_itemName = "Quarter/Chinese Coin Transformation";// column binding
$ATC_itemDescription = "";// column binding
$ATC_itemThumbnail = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = floatval("1");// column binding
$ATC_itemPrice = floatval("10.00");// column binding
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$UsedMagic->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $UsedMagic->redirStr == "") {
$UsedMagic->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($UsedMagic->redirStr != "") {
if (function_exists("rel2abs")) $UsedMagic->redirStr = rel2abs($UsedMagic->redirStr,dirname(__FILE__));
header("Location: ".$UsedMagic->redirStr);
die();
<html><!-- InstanceBegin template="/Templates/items-template.dwt" codeOutsideHTMLIsLocked="false" -->
<head>
<meta charset="utf-8">
<!-- InstanceBeginEditable name="doctitle" -->
<title>Used Magic - items</title>
<!-- InstanceEndEditable -->
<link href="../styles.css" rel="stylesheet" type="text/css">
<script src="https://ajax.googleapis.com/ajax/libs/jquery/3.5.1/jquery.min.js"></script>
<script type="text/javascript" src="file:///C|/Users/nikwa/OneDrive/Documents/WEBS/js/scripts.js"></script>
<!--The following script tag downloads a font from the Adobe Edge Web Fonts server for use within the web page. We recommend that you do not modify it.--><script>var __adobewebfontsappname__="dreamweaver"</script><script src="http://use.edgefonts.net/open-sans:n3:default.js" type="text/javascript"></script>
<!-- InstanceBeginEditable name="head" -->
</head>
<body>
<div class="background-image">
<div class="container">
<header>
<a href="/item.html"><img src="../pics/logo/logo01.jpg" alt="Used Magic items for sale" width="350" height="150"> </a>
<!-- InstanceBeginEditable name="ItemsMain" -->
<div class="items-main"><img src="../pics/large/Quarter-Chinese-(lge).jpg" width="400" height="285" alt=""/>
<div class="items-buy-button-holder items-price"><strong>£10.00</strong>
<form name="UsedMagic_1_ATC_QCCT_RB" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlentities($_SERVER["QUERY_STRING"]):""; ?>">
<input type="hidden" name="UsedMagic_1_ID_Add" value="QCCT_RB" >
<input type="image" src="../WA_eCart/Images/Pacifica/Btn1_EN_addtocart.gif" border="0" class="eC_ImageButton" value="Add to Cart" name="UsedMagic_1_ATC">
</form>
</div>
<div class="items-text">
<h1>QUARTER/CHINESE COIN TRANSFORMATION</h1>
<p>Magnetic quarter shim fits over Chinese coin. No instructions. Needs a magnetic shim to slip inside the sleeve or external magnetic source (eg a ring) to work the effect</p>
<p><br>
</p>
</div>
</div>
<!-- InstanceEndEditable --> </header>
<footer>
<div class="social-icons"><a href="mailto:nick@usedmagic.co.uk" target="_blank"><img src="../pics/buttons/facebook.png" alt="Used Magic Facebook page" width="99" height="52" class="facebook"><img src="../pics/buttons/email.png" alt="Email Used Magic" width="52" height="52" class="mail"></a></div>
<div class="copyright">Copyright USED MAGIC 2020</div>
</footer>
</div>
</div>
</body>
<!-- InstanceEnd -->
</html>
and the error message I am getting is:
Not Found
The requested URL was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Please attach pages you want me to look at instead of using copy/paste. I usually want to open them in Dreamweaver to see.
In this case I'd like to see a live version of the page as well. Can I get a url to view the problem and possibly ftp access to debug and fix it directly?
NWak04030229
You have:
but your cart page is in the root directory... so it should be:
$ATC_RedirectAfter = "../cart.php";
NWak04030229
many thanks
