Open popup box on checkout
Thread begun 9/21/2009 12:21 am by ZP | Last modified 9/21/2009 12:08 pm by Dani Chankhour | 1697 views | 1 replies |
ZP
With in Ecart 4.XX
I'm trying to open a modal box pop up window rather that go to a URL when the customer clicks checkout.
Below is the standard webassist ecart checkout code but I need to change this line...
$Redirect_redirStr="../Checkout/";
....to something that can run a script to open a modal box using:
MOOdalBox.open(
"http://www.mysite.com/Login/index.php",
"Some kind of caption",
"500 400" // width and height of the box - can be left blank
Does anyone have any ideas on how to run a javascript script with PHP?
Many Thanks In Advance
______________________________________________________________
Standard Webassist Checkout Code:
//WA eCart Redirect Check Out
if (isset($_POST["eCart1_Checkout_1"]) || isset($_POST["eCart1_Checkout_1_x"])) {
if ($Redirect_redirStr != "") {
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") === false) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "Checkout";
Dani Chankhour
You can replace this line:
with this line:
echo "<script>window.open('http://www.mysite.com/Login/index.php','Some kind of caption','500 400');</script>";
