Deprecated Error Message
Thread begun 6/10/2021 10:09 am by dhagood355349 | Last modified 6/10/2021 10:17 am by Ray Borduin | 542 views | 1 replies |
dhagood355349
I'm getting an error message on some webassist created pages
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/MySite/public_html/webassist/mysqli/authentication.php on line 202
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/MySite/public_html/webassist/mysqli/authentication.php on line 204
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/MySite/public_html/webassist/mysqli/authentication.php on line 349
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/MySite/public_html/webassist/mysqli/authentication.php on line 351
how can I fix this, it started today on pages created a year ago?
If you download and install the latest version of DataBridge, then re-apply one of your login related server behaviors, then that file will be updated and it will fix this issue.
You could also just turn off Deprecated messages in your php.ini file. They won't effect the functionality of the page, they are just warnings that they will not work in a future version and have to be updated at some point.
