Required field for State when other country selections available
Thread begun 6/08/2021 2:26 pm by lr_leal239405 | Last modified 6/10/2021 8:44 am by Ray Borduin | 1151 views | 3 replies |
lr_leal239405
A while back I had deleted all other countries outside of the USA on the checkout.php page generated by eCart. I now have added them back because we now will ship to other countries. However, I guess because the field is Required, it won't move on to display the CC payment box when pressing the Continue Checkout button. The input box for State that is hidden is conflicting with the dropdown select for 'State'. Where do I make it not required?
Thanks.
The checkout wizard will usually create javascript code that will change the state select list into a state text field and make it not required. If you removed that code too, maybe the best thing to do would be to run the checkout wizard again to re-generate it. It doesn't appear that you have done much other customization to the checkout page itself, so a fresh start might be the best option since that code would be complex to add back by hand.
Actually I viewed your source code on the checkout page, and maybe you do have too much customization to make re-running the wizard practical.
I could help write the javascript to swap out form elements and make the text field not required in a premier support ticket if you want to go that route.
lr_leal239405
Ok. I have other questions on other issues I have (probably pretty simple to resolve for you) with PHP/Javascript. I'll try calling after 12:00 pm EST. (or after 9:00 am your time)
lr_leal239405
I figured out the issue. It had to do with my own code, not Webassist code.
