Getting h2 and h3 headings from text in a recordset
Thread begun 6/08/2021 10:19 am by Mags | Last modified 6/08/2021 1:32 pm by Ray Borduin | 874 views | 2 replies |
Mags
Hi Ray, I have some HTML text in a database and I need to extract the h2 and h3 headings from the text to construct a table of contents. I found the following bit of code whilst searching online, but having tried to replace the html text example with the contents of the recordset, I can't get it to work. This is the code:
$headings='
<h2>This is heading h2</h2>
<h3>This is heading h3</h3>
function fnextractHeadins($headingtag, $headings)
$headingText = '';
preg_match_all( '|<'.$headingtag.'>(.*)</'.$headingtag.'>|iU', $headings, $headings );
foreach($headings[0] as $headh2val)
$headingText.=$headh2val;
return $headingText;
echo fnextractHeadins('h2', $headings);
echo fnextractHeadins('h3', $headings);
I want to replace the content shown in $headings with echo($rsRecordset->getColumnVal("ChapterText")); but my syntax must be wrong as it doesn't display anything. Can you help?
Try using:
echo($rsRecordset->getColumnVal("ChapterText",false));
The "false" disables the cross site scripting prevention code and allows html to be returned from the recordset.
Mags
I got it to work using the following:
$html = preg_replace_callback("#<(h[2-3])>(.*?)</\\1>#", "retitle", $rsRecordset->getColumnVal("ChapterText",false));
function retitle($match) {
list($_unused, $h2, $title) = $match;
$id = strtolower(strtr($title, " .", "--"));
echo "<$h2><a href='#$id'>$title</a></$h2>";
This also generates an id for each h2 and h3 heading so that it can be used as an anchor link.
Might be useful to someone else!
