binding dynamic checkbox not working
Thread begun 6/07/2021 4:43 am by Jose | Last modified 6/14/2021 8:48 am by Ray Borduin | 2771 views | 7 replies |
Jose
Hi there, I realized that Data Bridge doesn't work with dynamic checkbox while binding. I have try for more than a year with different version of Dreamweaver and it not working. It Always causes a Dreamweaver crash. I encourage you to do a test on it.
What version of Dreamweaver are you using? What build number? What OS?
It appears to work for me. I just added a checkbox and used the dynamic button in the latest version on Windows without issue.
Jose
I have tried it with Dreamweaver CC 2020 and 2021 and it doesn't works for me. I have windows 10 on my computer
We have the same setup and it works for me. That is a standard Dreamweaver interface that we don't add or remove code from, so I'm not sure how it would work differently.
Jose
Yes, it should be the same. Maybe I got something wrong. I will clean it up
Jose
I installed MySQLi Server Behaviors on Dreamweaver 2020 for testing and it works properly but when I use Data Bridge v2 by itself it doesn't works. I think that the issue occur on the Server Behaviors that use Data Bridge v2
That is very odd since they use the same exact code. I only have Data Bridge v2 installed and it works for me too. I'm glad you at least found a solution. I can try looking into it more on my end.
Jose
Yes, I finally fix it. I reinstalled Dreamweaver and all Web Assist Extension so now it works properly. Thank you so much for your answer.
