Cannot create connection using WA's Security Assist my Macbook Pro Catalina 10 15 7
Thread begun 6/02/2021 1:02 pm by randyrie405335 | Last modified 6/03/2021 8:13 am by Ray Borduin | 892 views | 2 replies |
randyrie405335
Getting a "an unidentified error has occurred" error when I try to use Security Assist to create a logon/password suite ... the MySQL server is running and PHP is working so how do I fix this? Let me know if you need access to my computer and I'll setup a time for us to RD.
This is usually an issue with the testing server settings in your dreamweaver site definition. Most likely a bad Web URL setting.
randyrie405335
Cannot create connection ...
Spot on, Ray!
I found an upper/lower case issue and when corrected... everything worked fine. And again, thanks for your prompt response.
