How do I add a session variable / value without it being part of the "storeResult" command @ login
Thread begun 6/02/2021 11:26 am by NavyChief | Last modified 6/02/2021 2:38 pm by Ray Borduin | 2922 views | 5 replies |
NavyChief
I have read a few of the threads on this and it "seems" my situation is a bit different. I cant seem to save session values from page to page if they are NOT stored using the "storeResult" command during login AND I cant even change the existing session values either. When users log in the login table has the values needed for the rest of the pages; however, admins log in in have no values because they should be able to choose a value and that part does not work.
In the example below I am altering the session variables based on selection from a form but I also want to add session vars outside of the login "storeResult" command.
LOGIN.PHP
<?php @session_start(); ?>
<?php require_once('/removed/Connections/conWEBPRO.php'); ?>
<?php require_once('/removed/webassist/mysqli/authentication.php'); ?>
<?php require_once('removed/webassist/mysqli/queryobj.php'); ?>
<?php require_once('/removed/webassist/mysqli/rsobj.php'); ?>
$Authenticate = new WA_MySQLi_Auth($conWEBPRO);
$Authenticate->Action = "authenticate";
$Authenticate->Trigger = ((((isset($_POST["un"]))?$_POST["un"]:"") != ""));
$Authenticate->Name = "username";
$Authenticate->Table = "security";
$Authenticate->addFilter("username", "=", "s", "".((isset($_POST["un"]))?$_POST["un"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".((isset($_POST["pw"]))?$_POST["pw"]:"") ."");
$Authenticate->storeResult("idx", "widx");
$Authenticate->storeResult("admlvl", "lvl");
$Authenticate->storeResult("username", "unm");
$Authenticate->storeResult("password", "upw");
$Authenticate->storeResult("email", "em");
$Authenticate->storeResult("wed_name", "wnm"); // <= initially saved here
$Authenticate->storeResult("wed_key", "wky"); // <= initially saved here
$Authenticate->storeResult("validated", "val");
$Authenticate->RememberMe = (true);
$Authenticate->SaveLogin = (true);
$Authenticate->AutoReturn = false;
$SuccessRedirect = "main.php?wk=".$_POST['wk'];
$FailedRedirect = "failure.php";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
{more after}
MAIN.PHP
<?php require_once('/removed/webassist/mysqli/queryobj.php'); ?>
if (true) {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "username";
$RestricAccessRedirect = "login.php";
if (function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
if ($_SESSION['val'] <> 0) { header("Location: noval.php"); }
if (($_SESSION['lvl'] == 9) && (isset($_GET['wk']))) {
$rsWEDLIST = new WA_MySQLi_RS("rsWEDLIST",$conWEBPRO,1);
$rsWEDLIST->setQuery("SELECT wed_name, wed_key FROM security WHERE wed_key = '".$_GET['wk']."' GROUP BY wed_name, wed_key ORDER BY wed_name ASC");
$rsWEDLIST->execute();
$_SESSION['wnm'] = ($rsWEDLIST->getColumnVal("wed_name")); // <= value changed here
$_SESSION['wky'] = ($rsWEDLIST->getColumnVal("wed_key")); // <= value changed here
{mopre after}
All other pages (example wlist.php) where $_SESSION['wnm'] and $_SESSION['wky'] are referenced show the stored value from login EXCEPT main.php shows the new values as if they are separate session vars.
I think somehow I need to get the session index key and provide it when I save other session vars post login.
Thoughts
Eric Joy
You probably just have to add:
@session_start();
before your code that resets the session variables. The webassist code closes the session once it is done, so you would have to re-start it in order to overwrite any values.
NavyChief
I am sorry but did you look closely.... I have @session_start();.... you did not see it??
Take a closer look at the attachments and/or my text above...
Yes, but it is above our code... We close the session once we are done. You need to open it again directly above your code that sets the session value.
The one you have on top is unnecessary since we open the session in the connection and authentication code, but we close it when we are done. That leaves it closed by the time your code runs.
NavyChief
I moved it there as a test... it was below the require_once's previously so I am clueless what you are talking about.
I have had it above at the top and below the last require once... I am confused as to where to put them.
@session_start() // <--- Put it here
