Is DA supposed to auto-populate form to DB relationships? - RESOLVED
If you look at DW's approach to inserting a record from a form, if form inputs use a name similar to the database table column name, it will automatically match up the fields to insert the form into.
Is DA supposed to also do this or does it require a manual process for matching database table fields to the form inputs?
steve
