ORDER BY problem
Thread begun 5/26/2021 8:43 am by Jamie | Last modified 5/26/2021 9:31 am by Ray Borduin | 1474 views | 3 replies |
Jamie
ORDER BY problem
Hey Ray
Have got this recordset
$WADAvehicle_inspections = new WA_MySQLi_RS("WADAvehicle_inspections",$DBConnection,20);
$WADAvehicle_inspections->setQuery("SELECT * FROM vehicle_inspections ORDER BY VehiclesDate DESC");
$WADAvehicle_inspections->execute();
<?php } else { ?>
$WADAvehicle_inspections = new WA_MySQLi_RS("WADAvehicle_inspections",$DBConnection,1);
$WADAvehicle_inspections->setQuery("SELECT * FROM vehicle_inspections WHERE VehiclesInspector = ? ORDER BY VehiclesDate DESC");
$WADAvehicle_inspections->bindParam("s", "".($_SESSION['UserLastName']) ."", "-1"); //colname
<?php } ?>
and this in a repeat block
<div class="coffee-span-2 resultsWrapper leftColumn"> <?php if(WA_Auth_RulePasses("Administrator")){ ?><a class="link-text resultsLinks dates timesheet" href="vehicleinspections_update.php?VehiclesID=<?php echo($WADAvehicle_inspections->getColumnVal('VehiclesID')); ?>
<?php echo(isset($_GET["pageNum_WADAvehicle_inspections"])?"&pageNum_WADAvehicle_inspections=".intval($_GET["pageNum_WADAvehicle_inspections"]):""); ?>"><?php echo(($WADAvehicle_inspections->getColumnVal('VehiclesDate'))?date('d M y',strtotime($WADAvehicle_inspections->getColumnVal('VehiclesDate'))):''); ?></a>
<?php } else { ?>
<?php } ?> </div>
it should be filtering/ordering by the date but as you can see by this screenshot its not http://prntscr.com/13g113t
Many thnaks
Jamie
What is the column data type for the VehiclesDate column in the database?
Jamie
dang
varchar - is there anyway to change it to date without it setting all dates to 0?
You can probably create a second column "tempDate" and then run a query like:
UPDATE vehicle_inspections SET tempDate =VehiclesDate
If it doesn't copy that way, then as long as you have a standard date format you might be able to get it to work with str_to_date() like:
UPDATE vehicle_inspections SET tempDate = str_to_date(VehiclesDate, '%Y-%m-%d')
see: https://www.w3schools.com/mysql/func_mysql_str_to_date.asp
Then once you are sure the dates got copied to the new column properly, delete the old column and rename the new one.
