Getting depreciated message
Thread begun 5/26/2021 6:45 am by software.current355386 | Last modified 5/26/2021 9:32 am by Ray Borduin | 1409 views | 3 replies |
my host provider is only going© to support php7.4 and above, and has provided a testing tool to check site compatility, on running get thhes messages
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/customer/www/studentsdrivingschool.com/public_html/webassist/mysqli/rsobj.php on line 145
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/customer/www/studentsdrivingschool.com/public_html/webassist/mysqli/authentication.php on line 204
how can this be rectifed
Download and install the latest version of DataBridge.
Then re-apply a recordset server behavior and a user authentication server behavior and the files referenced will be automatically updated.
THESE ARE LIVE SITES WHICH I DONY WANT TO CORRUPT IS THEREANY R ECORD SETS I CØU D USE TO SIMPLY TAKE ADDA CHAR SAVE ,
DELEET SAVE AAVE AGSIN
UPLOAD TO LIVESITE
Then is it case of updartind there tw o midule oon alllthe sites affected
The files that need to be updated are:
If you create a blank page and add a recordset and apply the user login server behavior, that would cause those files to be updated once you have the latest version of DataBridge installed. Then just upload those two files.
