How do I access Powerstore through Dreamweaver??
Thread begun 5/25/2021 7:59 am by Wenchofkrf | Last modified 5/28/2021 10:35 am by Ray Borduin | 5522 views | 19 replies |
Wenchofkrf
I have it on my server; how the blazes do I access it? I am really behind, and need to get this up and runnig!
What are you trying to update? You can access a lot through the admin website without dreamweaver. You can open pages in Dreamweaver if you want to edit the design templates or update the html on the pages.
Wenchofkrf
I have to rewrite the entire blessed site, and I have tried accessing through DW, as well as ftp client. I am rather frustrated, and sorry if I am asking a dumb question, but...
I'd need more specifics about what you are trying to update to be specific about how to update it.
You could look at these videos if any of them are applicable to what you are trying to do:
https://www.youtube.com/results?search_query=webassist+powerstore
Wenchofkrf
OK, I need to get into the admin area, so I can get the site up and running. I cannot figure out how to get in there, to set things up.........
Login to the admin back end here:
http://starfireswords.com/PowerStore/admin/home.php
Wenchofkrf
Thank you so much!
Wenchofkrf
Deprecated code?
I'm sorry to be a pest, but when I went to start adding my first product, I got the following mess when I hit save:
Deprecated: strpos(): Non-string needles will be interpreted as strings in the future. Use an explicit chr() call to preserve the current behavior in /home4/starfir3/public_html/PowerStore/webassist/form_validations/wavt_scripts_php.php on line 470
Deprecated: strpos(): Non-string needles will be interpreted as strings in the future. Use an explicit chr() call to preserve the current behavior in /home4/starfir3/public_html/PowerStore/webassist/form_validations/wavt_scripts_php.php on line 474
Deprecated: strpos(): Non-string needles will be interpreted as strings in the future. Use an explicit chr() call to preserve the current behavior in /home4/starfir3/public_html/PowerStore/webassist/form_validations/wavt_scripts_php.php on line 496
Deprecated: strpos(): Non-string needles will be interpreted as strings in the future. Use an explicit chr() call to preserve the current behavior in /home4/starfir3/public_html/PowerStore/webassist/form_validations/wavt_scripts_php.php on line 499
INSERT INTO ps4_products (`ProductSKU`, `ProductName`, `ProductPrice`, `ProductRetailPrice`, `ProductShipping`, `ProductWeight`, `ProductCartDesc`, `ProductShortDesc`, `ProductLongDesc`, `ProductThumb`, `ProductImage`, `ProductStartDate`, `ProductEndDate`, `ProductStock`, `ProductLive`, `ProductUnlimited`, `ProductDigital`, `ProductMaxDownloads`, `ProductNonTaxable`, `ProductTitle`, `ProductMetaKeywords`, `ProductMetaDescription`, `ProductConfiguration`) VALUES ('4\" Lady\'s Dagger', '4\" Lady\'s Dagger', 135, 0, 0, 0, 'The information you enter here will display on the Shopping Cart page when your customer adds this product to their cart.', 'Here you should enter a short description of this product. The information entered here will display on the product catalog page (this field is not used for grid results pages).', '
The long description should be used to detail all the aspects of this product. This could include the following:
\r\n\r\n
\r\n
Technical Specifications
\r\n
Instructions
\r\n
Product Reviews
\r\n
Image gallery of the product (select the \'Insert Photo Gallery\' button from the toolbar)
\r\n
\r\n', 'default-product_thumb.png', 'default-product.png', NULL, NULL, 0, '1', '1', '', 0, '', '', '', '', '')
Unknown column 'ProductConfiguration' in 'field list'
I fixed these issues on your site. Let me know if you run into anything else.
Wenchofkrf
Thank you for the fix, but I seem to have 1 more issue; I cannot update a product. I left something out, and went to fix it, and got:
Update ps4_products set ProductName = '8\" Dagger without Quillion', ProductSKU = '8\" Dagger without Quillion', ProductLongDesc = '
\r\n\r\n
\r\n
\r\n
Instructions
\r\n
Product Reviews
\r\n
\r\n
\r\n', ProductUpdateDate = '2021-05-26 13:06:18' WHERE ProductID in ( select Distinct ProductID from ps4_productoptions where ) OR ProductID = 5
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') OR ProductID = 5' at line 1
