master / detail repeat loop
Thread begun 5/24/2021 1:05 pm by rayne202093 | Last modified 5/25/2021 9:52 am by Ray Borduin | 1030 views | 2 replies |
rayne202093
I have this recordset:
$master1events = new WA_MySQLi_RS("master1events",$clarion_i,20,0);
$master1events->setQuery("SELECT * FROM (events LEFT OUTER JOIN eventsDate ON events.events_ID=eventsDate.event_IDfk) WHERE events.no_display IS NULL AND eventDate >= CURDATE() AND (canceled IS NULL || canceled = 0) AND (upcoming IS NULL || upcoming = 0) GROUP BY event ORDER BY eventsDate.eventDate ASC");
$master1events->execute();
And this code:
<table border="0" cellpadding="0" cellspacing="0">
$wa_startindex = 0;
while(!$master1events->atEnd()) {
$wa_startindex = $master1events->Index;
<tr>
<td>
<p class="event-online"><strong><?php echo $master1events->getColumnVal('hp_online'); ?></strong></p>
<p class="event-title"><?php echo $master1events->getColumnVal('eventimg',false); ?> <?php echo $master1events->getColumnVal('event'); ?></p>
<p class="event-desc"><?php echo $master1events->getColumnVal('desc_front'); ?></p></td>
</tr>
if ($master1events->TotalRows>0) {
$detail2eventsDate = new WA_MySQLi_RS("detail2eventsDate",$clarion_i,1);
$detail2eventsDate->setQuery("SELECT * FROM eventsDate WHERE eventDate >= CURDATE() AND (canceled IS NULL || canceled = 0) AND (upcoming IS NULL || upcoming = 0) AND event_IDfk= ". $master1events->getColumnVal('events_ID') ." ORDER BY eventsDate.eventDate ASC");
$detail2eventsDate->execute();
$nested_sw = false;
while (!$detail2eventsDate->atEnd()) {
<tr>
<td><p class="event-para"><strong><?php echo $detail2eventsDate->getColumnVal('location'); ?></strong>: <?php echo $detail2eventsDate->getColumnVal('dateDisplay'); ?>
// Show IF Conditional region1
if ($detail2eventsDate->getColumnVal('link')) {
<a href="<?php echo $detail2eventsDate->getColumnVal('link'); ?>">Read more</a>
if ($detail2eventsDate->getColumnVal('regLink')) {
| <a href="<?php echo $detail2eventsDate->getColumnVal('regLink'); ?>">Register</a>
<?php }
// endif Conditional region1
// Show IF Conditional region5
if ($detail2eventsDate->getColumnVal('online') == 1) {
&nbsp;<em>(Online or In-person)</em>
<?php }
// endif Conditional region5
</p>
<?php }
?></td>
</tr>
$detail2eventsDate->moveNext();
<tr>
<td>&nbsp;</td>
</tr>
$master1events->moveNext();
$master1events->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
</table>
The master record is repeating as it should but only one detail record is shown beneath each master. So the detail record is not repeating. The part of the code between the <!-- -------------------------------- --> should be repeating.
Can you tell me where I made an error in the code?
Thanks.
This line:
The "1" at the end is the number of rows to return... "0" returns all rows, so you can just change it there manually.
rayne202093
That worked. Thank you so much!
