Search functionality not working
Thread begun 5/17/2021 1:20 pm by rogersds267040 | Last modified 5/17/2021 5:51 pm by Ray Borduin | 2643 views | 8 replies |
rogersds267040
Hoping to get some help with a search functionality.
Created a search set with 3 fields. None of them since to work. Calling a record set with multiple UNIONs.
Your form tag has: method=post
It should be: method="post"
rogersds267040
Thank you very much.
Unfortunately, that didn't resolve the issue.
Can I get FTP access and a URL to reproduce? It will be much easier to debug if I have access to the code and can test the page.
rogersds267040
Details in private.
I updated the page so I think it will work.
However the recordset doesn't have any results returned to begin with, so I couldn't really test it fully.
rogersds267040
Thank you for your quick response. It's working fine.
Is there something I need to be aware of when creating the search?
Any tips provided are appreciated.
You need to wrap UNION SELECTS into a single select statement and add a WHERE at the end to help the search code identify where to add the code properly. You can see the updated SQL statement in your recordset that I used to make it work properly.
rogersds267040
Thank you Ray for your quick response.
