Can I customize any of eCart settings
Thread begun 5/15/2021 7:30 am by NWak04030229 | Last modified 5/18/2021 9:38 am by Ray Borduin | 1326 views | 3 replies |
NWak04030229
I have got over 400 items to process through eCart for a website. Is there any way of customizing the General and Button pages in the Add eCart Button? I use the same page to direct to and also the same button at the end which is in the Slate category. Just wondered if any way of saving a bit of time?
Yes, everything can be customized. You can get the values from the database and add columns... really whatever you need should be possible.
NWak04030229
Ray - don't know if I didn't put it right in the original message. I am putting over 400 items on a website - every time I open up the Add to Cart programme I have to enter the page to redirect to (ie cart.php) then the next tab I put in all the details (which is fine as that is different every time) then on the last tab I have to select Slate and then the button I want to use. I wondered if those first and last tabs could have the details already loaded as defaults
I see. No, unfortunately you would have to put those in each time.
You could copy/paste the Add to cart code from the first page and add it to all of the other pages. Then they would all be populated when you opened the server behavior and you would be able to just update the product details.
