File Upload Not Working
Thread begun 9/20/2009 7:44 pm by dataworks388155 | Last modified 9/23/2009 8:56 am by Jason Byrnes | 6181 views | 7 replies |
dataworks388155
I can't seem to get File Upload to work from a form that is uploading more than one file.
It works ok on a simple trial page with one upload, but I require to have 1 image and 3 documents uploaded on one form. The script just seems not to do anything. No error messages or anything, but nothing is being uploaded.
Here is the code for the uploads...
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "Members/PrimaryScools/",
'FileName' => "Logo",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'UploadFolder' => "Members/PrimarySchools",
'FileName' => "Logo_thumb",
'ResizeType' => "4",
// WA_UploadResult1_2 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'FileName' => "MissionVision",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End?>
// WA_UploadResult3 Params Start
$WA_UploadResult3_Params = array();
// WA_UploadResult3_1 Start
$WA_UploadResult3_Params["WA_UploadResult3_1"] = array(
'FileName' => "SongPrayer",
// WA_UploadResult3_1 End
// WA_UploadResult3 Params End?>
// WA_UploadResult4 Params Start
$WA_UploadResult4_Params = array();
// WA_UploadResult4_1 Start
$WA_UploadResult4_Params["WA_UploadResult4_1"] = array(
'FileName' => "RulesRegs",
// WA_UploadResult4_1 End
// WA_UploadResult4 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "Logo", "0", "", "true", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "MissionVision", "0", "", "false", $WA_UploadResult2_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult3");
WA_DFP_UploadFiles("WA_UploadResult3", "SongPrayer", "0", "", "false", $WA_UploadResult3_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult4");
WA_DFP_UploadFiles("WA_UploadResult4", " RulesRegs", "0", "", "false", $WA_UploadResult4_Params);
Help, please
Compress the entire php page into a zip file and attach the zip file to your reply so I can look at the code in context.
dataworks388155
Hermes
Thanks.
This is the Error displayed on the page
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /hermes/web01c/b1006/hy.dcrawford/reportbookrequest.php on line 589
Entire file is attached
most likely you have deleted a recordset from the page but the mysql_free_result() for it was left over.
You can probably delete line 589.
i need to see the original PHP page, not the source after running it in the browser. Please compress the PHP page into a zip archive and send it with your reply.
dataworks388155
Hermes
Sorry.
Here it is
The forms action is set to post to formemail.bml. because it is posting to another page, the upload never has a chace to occur.
When a form posts, the information goes directly to the action page, the upload will not occur.
The only way for the upload to occur is if the action of the form is set to post to itself.
Also the Forms Encoding type needs to be set to multipart/form-data
dataworks388155
Solved.
Thank you.
Works perfectly now.
Unable to get a progress bar, though. I am seeing the action inserted in the Dreamweaver page, but nothing is visible when the script runs.
Dexter
Make sure to upload the WA_DigitalFilePro folder to the server after applying the progress bar. If it is still not working, send a copy of the PHP page so I can examine the code.
