When header parameter is encrypted with wa_sha1encryption, it breaks when it has "+"
Thread begun 5/14/2021 5:51 am by rogersds267040 | Last modified 5/17/2021 3:50 pm by Ray Borduin | 2153 views | 6 replies |
rogersds267040
Appreciate some help in solving this issue.
When a header parameter is encrypted with wa_sha1encryption the encrypted value has a "+", the application breaks and does de-crypt properly
Do you have an example I can use to debug?
rogersds267040
Thank you, sir.
I'm trying to reproduce the error and send it to you. As indicated, it happens when the encrypted value has a + sign.
rogersds267040
Hi Ray,
I have attached two screenshots to this message. The first shows when the encryption happens without the +plus sign, it renders properly. When the encrypted value has a + sign, I get a white page. I also attached the listing page and the detail.
Let me know if you want to see the behavior live.
I have also added 2 instances of values that I tried to encrypt using has and the encrypted value. You can see the + plus sign which causes issues.
3OJ869kp5uofXrlZ0W4MygwPct2NeR - mLi4q5ur35Cu5OTYeOTNyJTGoW3s2+m50dtStsrE
B6Qj3z2Jwhkciu1oYtIaxpbdyrXLAl - p5+/3Zjspmrw1+DVieeS3b3jtoHr5NTN59l4tKbe
The plus symbol is converted to a space in a url. You probably have to replace the plus signs with %2B
rogersds267040
Thank you, Ray.
I assumed that I needed to do some extra work. Since the plugin generates the encrypted value, thought that was an easier way.
Just use str_replace() to replace the + with %2B when the url is generated.
