Changing the cart's name - problems using same cart name over more than one domain
Thread begun 5/12/2021 8:50 am by Nathon Jones Web Design | Last modified 5/12/2021 9:21 am by Ray Borduin | 1196 views | 3 replies |
Hi. How do you change the name of a cart? It's greyed out / unavailable for edit when you open the cart properties.
Thank you.
NJ
There shouldn't be issues using the same cart over more than one domain.
You would have to do a site-wide find and replace to change the cart name. It isn't recommended.
I'm working locally for now, but I assume (oh jeez!) that it would be the same in a live scenario.
If I add a product to cart whilst testing this project, let's say the URL is:
http://localhost/tammyssweetstems/product.php?pID=12
...and I then view cart on another project that uses the same cart name:
http://localhost/thevaultartscentre/view_basket.php
...the product from the other project is in the cart. :S
NJ
That is only happening because you are on the same domain and they share a session.
This won't be an issue once they are on separate domains.
