Multi Image Upload
Thread begun 5/10/2021 2:40 am by georgina_barrett_187762 | Last modified 5/10/2021 1:07 pm by Ray Borduin | 898 views | 2 replies |
Multi Image Upload
Sorry - me again ;)
I thought I had managed to get this to work after speaking to you, but the image name just doesn't insert into the database. The image itself uploads ok and the correct number of records insert into the database (if I add 1 image - 1 record is inserted, if I add 2 images - 2 records are inserted) but the image field is always empty. I have inserted the server file name from the bindings panel into my page to check the path is correct and it is (below is the server file name of the first image)
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"]; ?>
I have attached my page
On line 123 you have:
$_SESSION['uploadedFiles'][i]
It should be:
$_SESSION['uploadedFiles'][$i]
That fixed it - than you!
